InterVLAN routing on Cisco SF300-24PP
KimC1992
I’m stuck trying to route between VLANs.
I have a Cisco SF300-24PP set in L3 system mode. I also have an EdgeCore ECS2100-28T L2 switch.
Port 1 on both switch is on VLAN 101 untagged. Port 2 on both switch is on VLAN 102 untagged. The switches are connected on trunk ports.which are tagged members of VLANS 101, 102 and 1 (myLoneStar login).
VLAN101 on the Cisco has address 192.168.1.254.
VLAN102 on the Cisco has address 192.168.2.254.
VLAN1 on the Cisco has address 192.168.98.254.
I can connect a PLC, address 192.168.1.55, on port 1 on the Edgecore switch and ping it from a PC on port 1 on the Cisco switch ok.
I can connect a the same PLC on port 2 on the Edgecore switch and ping it from a PC on port 2 on the Cisco switch ok.
What I need to be able to do is ping [and go online to the PLC] with the PC on port 1 on the Cisco switch and the PLC on port 2 on the Edgecore switch, i.e. between VLANs, and only in that direction..
The PC has address 192.168.1.200/24, gateway 192.168.1.254.
The PLC has address 192.168.2.100/24.
I thought that ACL binding on port 1 or VLAN101 of the Cisco would do the trick for me but I can’t get it to work.
The ACE I was using is attached.
Can anyone help with the routing?
kristoff1
Hi Kim,
You need to enable ip routing on your switch where the svi's are on.
If they are on the same switch this should do the trick.
Kind regards,
kristoff
--> Port 1 on both switch is on VLAN 101 untagged. Port 2 on both switch is on VLAN 102 untagged. The switches are connected on trunk ports.which are tagged members of VLANS 101, 102 and 1 (default).
It is difficult to understand what you have configured. There can only be one (untagged) Vlan.
I think the SF300 let's you do a 'sh run', post the output of that, and indicate which ports are connected to which devices.
