intervlan vlan 1 gateway
humberjet
question, i have setup 3 vlans on my network..
servers are configured on vlan 1...
routers are also configured on vlan 1..
problem is i cant ping vlan 1 using vlan 2 or 3 source.. but I can ping directly on vlan 1..
any idea..
10 Replies 10
Reza Sharifi
Can you post your config?
Also, what type of routers and switches are you using?
Vlan 1 may need a default route.
no aaa new-model
switch 1 provision ws-c3750g-24ts
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 5
spanning-tree portfast
interface GigabitEthernet1/0/14
switchport access vlan 3
interface GigabitEthernet1/0/15
interface Vlan1
ip address 10.0.0.2 255.255.0.0
interface Vlan3
ip address 10.3.0.1 255.255.0.0
interface Vlan4
ip address 10.4.0.1 255.255.0.0
interface Vlan5
ip address 10.5.0.1 255.255.0.0
ip helper-address 10.0.0.4
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.254.137
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
where can i put the default route on VLAN 1
can you show your layout please here ??
you need to plug a device into your vlan access ports otherwise your vlan interface may  not be UP/UP and so your pings with the source vlans won't work.
Can you post sh ip int br | i Vlan
Regards.
Alain.
Mark June Almosara wrote:
no aaa new-model
ip subnet-zero
ip routing
interface Vlan1
interface Vlan3
interface Vlan4
interface Vlan5
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Hello ,
The default route will be pointing towards the external world , if your segment wants to talk to other subnet extrnl to segment...
Ganeshh Iyer
Hari Haran S M
Hi Mark,
As said by Cadet, you have to make sure that all the SVI interfaces are UP. If you are not able ping even though they are up, you have to check the default gateway configured on the machine that you are trying to reach. A default route is not required here as all the three vlan's are in the same device and hence, they should be in directly connected state.
Hari
yup all my SVI's are up
l
Vlan1                  10.0.0.2        YES manual up                    up
Vlan3                  10.3.0.1        YES manual up                    up
Vlan4                  10.4.0.1        YES manual up                    up
Vlan5                  10.5.0.1        YES manual up                    up
if im on vlan 1 i can ping all SVIs.. but if Im on Vlan 3-5.. i cant ping all members on vlan1..
Hi Mark.
You said "i cant ping all members on vlan1" , I would check couple things :-
1> Local Firewall like Windows Firewall or linux IPtables on those devices filtering ICMP.
2> Check port assignment for those for correct VLAN & switchport Mode.
Manish
anyway i can ping all host on VLAN 1 I set their default gateway to 10.0.0.2...
my problem now is my router connected to VLAN 1.. cant ping the router thru vlan 3-5..
U think i need to add routing table to my router or on my Firewall.. any suggestion?
here is my diagram..
          Cisco Router
          SSG 20 (firewall)
          Catalyst 3750 (L3)
Depends upon the way you have configured your firewall. If the firewall is configured in routed mode than yes you will need default from your L3 switch to firewall , than from firewall to router. similarly you will need routes at the router & firewall to have routes for your internal network.
for example :-
router ----------------------------------------------------------- Firewall ------------------------------------------------------------------MLS ----|
192.168.10.1/30                      192.168.10.2/30           192.168.20.1/30                        192.168.20.2/30         |
        10.10.10.0/24
        10.10.20.0/24
MLS : default route 0.0.0.0 0.0.0.0 192.168.20.1
Firewall : Default route 0.0.0.0 0.0.0.0 192.168.10.1
              static routes 10.10.10.0/24 points to 192.168.20.2
              static routes 10.10.20.0/24 points to 192.168.20.2
Router : default 0.0.0.0 0.0.0.0 ISP-Next-Hop
             static routes 10.10.10.0/24 points to 192.168.10.2
             static routes 10.10.20.0/24 points to 192.168.10.2
If your firewall is not routed than you you can skip the routes parts on the firewall and adjust next hops as needed.
Manish
