IOS C4507R (12.2.25-EWA11) serious software issue
edgar_pascal
i found message in IOS software download
that IOS cat4000-i9k91s-mz.122-25.EWA11 found serious issue?
What IOS recommendation to replacement that IOS ?
Currently i'm using cat4000-i9k91s-mz.122-25.EWA11 in C4507R.
Lian
upgrade
Giuseppe Larosa
Hello Lian,
the message is a disclaimer:
Cisco advices you the image is affected by a problem.
The problem is related to L2TP.
Other problems apply to OSPF or other L3 features.
If you are using the device as a L2 switch only actually none of these issues is of interest for you.
One is about SSH, again if you don't use SSH this is not a problem.
A suggestion for a later release can be done but a sh module would be needed to see what supervisor is installed.
However, the advice says that release 12.2(25)EWA12 is not affected
So I would try to download 12.2(25)EWA12.
Hope to help
Giuseppe
glen.grant
You might want to move to the SG train as the EWA train is eol in November of this year.
Hi Giuseppe,
thanks for the help i'm waiting for the EWA12.
Hi Glent,
what type of IOS SG train recommendation ?
Lian
here is my sh module C4507R:
C4507R#sh module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE11485C73
2 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE11485KE3
3 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE114749UR
4 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE11474D7L
5 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE11474GQS
6 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1235T5IK
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1237UUM6
M MAC addresses Hw Fw Sw Status
1 001e.4aea.0d00 to 001e.4aea.0d01 4.5 12.2(31r)SGA 12.2(25)EWA11, Ok
2 001e.4aea.0d02 to 001e.4aea.0d03 4.5 12.2(31r)SGA 12.2(25)EWA11 Ok
3 001e.7a2f.4d60 to 001e.7a2f.4d8f 2.4 Ok
4 001e.13cf.b160 to 001e.13cf.b18f 2.4 Ok
5 001e.4af4.5010 to 001e.4af4.503f 2.4 Ok
6 0023.0460.6200 to 0023.0460.622f 2.5 Ok
7 0023.33a1.55e0 to 0023.33a1.560f 2.5 Ok
Mod Redundancy role Redundancy mode Redundancy status
1 Standby Supervisor SSO Standby hot
2 Active Supervisor SSO Active
