IOS for Cisco 2620 48mb
whiteford
I've search for ages to find an IOS for my Cisco 2620 router that has 48mb and can support the feature "ip http secure-server" is there an easy way to find this?
It seems the SDM gui tool needs this feature to work. My other Cisco 2620 has 96mb and has a bigger IOS but it can run that feature I mentioned and run the SDM tool.
Is there a IOS or do I need more memory?
adkumar_2
Hi There,
Features are IOS Dependent. & Each IOS version has its Minimum Requirements in terms of DRAM & FLASH.
For Your knowledge sake, we can Choose the IOS as per our Requirements using Cisco Feature Navigator @ http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
However, we need a CCO ID to access it.
In any case, I'd appreciate If you can provide "sh version" from both Routers , so that I can Provide the Exact Solution.
Hi, router b is fine and has 64mb (thought it was 96mb).
router a has 48mb, the SDM express installs onto router b but not router a. Both routers are C2620's.
The only parts I can't add to router a's config which I think are needed are "ip http secure-server" "transport input telnet ssh"
Router b
sh ver
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
RouterB uptime is 1 minute
System image file is "flash:c2600-ik9o3s3-mz.123-26.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 2620 (MPC860) processor (revision 0x200) with 61440K/4096K bytes of memory.
Processor board ID ******* (1277056474)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
router a
RouterA#sh ver
IOS (tm) C2600 Software (C2600-IK9O3S-M), Version 12.2(46a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 11-Jul-07 20:22 by pwade
Image text-base: 0x8000808C, data-base: 0x812D9374
RouterA uptime is 0 minutes
System image file is "flash:c2600-ik9o3s-mz.122-46a.bin"
export@cisco.com.
cisco 2620 (MPC860) processor (revision 0x200) with 45056K/4096K bytes of memory.
Processor board ID ******** (3902584544)
Bridging software.
On Router a, we have 64 Mb RAM
On Router b, we have 48 Mb RAM
The Features HTTP Server & HTTP with SSL are Supported in 12.3 Line of Code & the min. requirements I found were 64 Mb RAM.
So I am afraid that a RAM Upgrade is required as I didnt find any IOS (with Required features) & 48 Mb RAM Combination.
I'd appreciate if you can have a Look @ Cisco feature Navigator yourself to try various Permutations & Combinations as Desired
Thanks & regards
