IOS for QOS commands and IP Routing
Shaheen Sidana
Hi Everyone,
I am having a 4503 chassis with SUP6L-E and using this as my core device in network. I want to use full IP Routing with EIGRP and also want to use auto qos and mls qos. Below are the commands i want to use as per client requirement. Please suggest the appropriate IOS.
qos dbl
qos map dscp 0 to tx-queue 2
qos map dscp 16 18 20 22 24 26 28 30 to tx-queue 4
qos map dscp 32 34 36 38 to tx-queue 4
qos map cos 5 to dscp 46
interface TenGigabitEthernet1/1
description *** Trunk to CORE-2 ***
switchport mode trunk
qos trust dscp
service-policy output DBL
tx-queue 3
priority high
shape percent 30
channel-group 1 mode on
Thanks & Regards,
Shaheen Sidana
Reza Sharifi
If you need full IP routing, you need the Enterprise license.  IP base supports only EIGRP Stub.
have a look at tthis link for more info:
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/at_a_glance_c45-619755.pdf
