IOS issues
haris.cisco
Level 2
Level 2
i want to know which services are enabled by default on a specific IOS
regards
Haris
desai.jaideep
Level 10
Level 10
Pls be specific which IOS?
(1)Give the hardware (router/switch etc)
(2)Specify the version(12.3, 12.4)
(3)Its IPbase, IP Plus, Advance security?
Or
Give the IOS name.
Pls follow following link, it will help u.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Note: pls rate the post if it helps.
thnks
but this link gives me the feature set but not the service enable by default
like ip http service enable or disabled
or tcp small service enable or disabled
waiing for ur response
Thats a good one.So far I have heard only about "IP Routing" is enabled by default which does not reflect in the active running config.It is hard to say that what will be the default service which will be enabled.
Every IOS set has different "default" values.For Eg. a C1721 with 12.2 IP Plus has following :
logging queue-limit 100
ip subnet-zero
ip cef
ip audit notify log
ip audit po max-events 100
ip classless
This may vary with a C2600 config 12.3
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
control-plane
ip audit notify log
But these commands are visible in show running-config. unlike ip routing.You can always negate a running command.
There is no written document about this, hence I am not able to explain more.But above is what I have concluded.Also it will be a great help if you can tell me" what you want to do?"
JD
thanks for your response JD
what i want to know is there any tool which gives me the default services enabled on a SUP 720 when using an IOS "s72033-jk9sv-mz.122-18.SXD.bin"
these services will not be seen in the running config of the router say for example
tcp small-server & UDP small-server these small services are enabled by default before version 11.3 but later they are disabled
waiting for ur reply
