IOS load failure for Cisco switch 2960
Nabaruma
I have a Cisco 2960 switch that has an old ios (c2960-lanbase-mz.122-25.SEE2.bin) which i want to replace with a new ios (c2960-lanbasek9-mz.122-55.SE.bin) which I successfully uploaded from my tftp server.
The new ios has been uploaded to the switch flash and boot change to the new ios (using the command: boot system flash:) but the switch still load from the old ios even after reload.
I have reloaded several times and even tried using this command ( no boot system flash:....old ios...) but all to no avail.
Someone please should help.
Thanks guys in advance.
Usman Musa.
Jon is correct missing boot statement
2960(config)# boot system flash:c2960-lanbasek9-mz.122-55.SE.bin
2960(config)#Wr mem
2960(config)#show boot
Run show boot to verify that boot statment is set prior to reload
you should see a statement that says "boot=" or BOOT path-list
2960(config)#reload  < will reload the switch and apply new image, since you stated its a live network, schedule a maintiance window and do it afterhours
Best of luck!
10 Replies 10
Leo Laohoo
Why not delete the old IOS?
Nice suggestion, but it's actually a live switch and I'm scared to take that risk!
Jon Marshall
Usman Musa.
Usman
Can you post -
1) "sh version" from switch
2) dir /all or dir bootflash: from the switch
3) the running config of your switch
Jon
Hi Jon,
I have triend show boot ealier and it showed the booting is on the new ios.
Anyway i have attached the commands that you said i should run on the swicth.
Usman
I cannot see any "boot system flash" command in your running config ?
Please add this to your config and try reloading again -
2960(config)# boot system flash flash:/c2960-lanbasek9-mz.122-55. SE.bin
Jon
Hi ALL,
I'm alright now. The swicth has loaded the new ios after using the following commands:
#no boot system flash:c2960-lanbase-mz.122-55. SE.bin
#boot system flash:c2960-lanbasek9-mz.122-55. SE.bin and reloaded.
I really appreciate you all.
Usman.
No problem, glad you got it fixed.
Jon
pragpat
Hi Usman,
try "show boot "
this will tell you the boot variable, boot loader and configration registor. This way you can verify the boot variables before reloading
Pretty usefull command
Hope that helps.
Prag
show boot
Use the show boot privileged EXEC command to display the settings of the boot environment variables.
show boot [ | {begin | exclude | include} expression]
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/sof
2960(config)#Wr mem
Best of luck!
Nabaruma
Hi ALL,
Usman.
