iOS port forwarding commands for Port Forwarding
jkruljac
I am trying to open up port 32400 on my 881w Cisco router but I have not had any success I need to configure manual port-forward to enable my Plex Media server. Can someone help me out wiht this set of cmds?
Thanks!
5 Replies 5
blau grana
Level 7
Level 7
Hello Jonathan,
You have to configure ip nat inside on inside (LAN) interface and ip nat outside on WAN interface.
Then you canconfigure portforward:
ip nat insdie source static tcp 10.0.0.10 1122 150.0.0.1 2233
tcp - protocol, which you want to forward TCP/UDP
10.0.0.10 - IP address of your private device
1122 - port on your private device which you want access
150.0.0.1 - public IP which will represent your private device in internet
2233 - public port which will be forwarded to defined port on private device
Make sure that you do not filter traffic with ACL on your WAN or LAN interface.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hai friends,
               How to get cisco router configuration backup in .txt
What does this question about router backup of config have to do with the subject of this 3 year old discussion of opening ports for port forwarding? You would be much better off to start a new discussion.
Rick
Rick
GarrettSkj
I'd recommend using a route-map to do the port fowarding, you can find something along the lines at my blog post (shameless plug) here.
http://ping8888.com/2014/01/21/cisco-ios-port-forwarding-pat/
ayoubzniber71
I have the same problem I have the routing between r4 and r1 the ping pass well but I have no routing ente r1 and r3 So I have to do port mapping so that I can connect r4 with r3 through the port of http 80 I try with nat and por-map but it does not work.
if we have a solution send to me
thank you in advance
