IOS Upgrade Issue
Rawa Salah
Level 3
Level 3
Dears
please help me , During I upgraded my Cisco Switch 3750x , during booting this issue was occured , the booting dont be finish, please help for solving
-Frame 09: SP = 0x055D7270    PC = 0x00688C68
Frame 10: SP = 0x055D7378    PC = 0x00688EA0
Frame 11: SP = 0x055D7380    PC = 0x02D5771C
Frame 12: SP = 0x00000000    PC = 0x02D51C54
Switch uptime is 8 minutes, 10 seconds
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1701W1GR
01:35:40 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
-Traceback= 0xFFFFFF2Cz
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(1)E, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 11:06 by prod_rel_team
Program Exception (0x0700)!
SRR0 = 0x04002F60  SRR1 = 0x00029230  SRR2 = 0x02898534  SRR3 = 0x00029230
ESR = 0x08000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x00000000
CPU Register Context:
Vector = 0x00000700  PC = 0x04002F60  MSR = 0x00029230  CR = 0x35000053
LR = 0x02005414  CTR = 0x00000000  XER = 0xE0000010
R0 = 0x00000000  R1 = 0x055D6E80  R2 = 0x00000000  R3 = 0x055D6EA0
R4 = 0x00000031  R5 = 0x055D6F54  R6 = 0x00000018  R7 = 0x0534A693
R8 = 0x0000001D  R9 = 0x0534A690  R10 = 0x00000017  R11 = 0x00000050
R12 = 0x00000000  R13 = 0x0B98279C  R14 = 0x00688E58  R15 = 0x00000002
R16 = 0x00000000  R17 = 0x0534A690  R18 = 0x00000001  R19 = 0x00000099
R20 = 0x04E2CDCD  R21 = 0x051D0000  R22 = 0x00000000  R23 = 0x00000002
R24 = 0x00000001  R25 = 0x055D6ED4  R26 = 0x04E2C9F8  R27 = 0x00000036
R28 = 0x00000004  R29 = 0x04E2C9D8  R30 = 0x05FEE5D8  R31 = 0x0000003A
Stack trace:
PC = 0x04002F60, SP = 0x055D6E80
Frame 00: SP = 0x055D6F98    PC = 0x020052CC
Frame 01: SP = 0x055D70C8    PC = 0x02006668
Frame 02: SP = 0x055D70E8    PC = 0x02006CCC
Frame 03: SP = 0x055D7198    PC = 0x02006FB4
Frame 04: SP = 0x055D71B8    PC = 0x028D881C
Frame 05: SP = 0x055D71F8    PC = 0x026BC780
Frame 06: SP = 0x055D7208    PC = 0x022AA47C
Frame 07: SP = 0x055D7228    PC = 0x022AA648
Frame 08: SP = 0x055D7240    PC = 0x022AA798
Switch uptime is 8 minutes, 12 seconds
01:35:43 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 15 seconds
01:35:45 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 18 seconds
01:35:48 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 20 seconds
01:35:50 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 23 seconds
01:35:53 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 25 seconds
01:35:56 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 28 seconds
01:35:58 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 31 seconds
01:36:01 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 33 seconds
01:36:04 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 36 seconds
01:36:06 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 39 seconds
01:36:09 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 41 seconds
01:36:11 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 44 seconds
01:36:14 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 46 seconds
01:36:17 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 49 seconds
01:36:19 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 52 seconds
01:36:22 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 54 seconds
01:36:24 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
Stack trace:
Switch uptime is 8 minutes, 57 seconds
01:36:27 UTC Wed Mar 30 2011: Unexpected exception to CPUvector 700, PC = FFFFFF2C
8 Replies 8
Gregory Snipes
Level 11
Level 11
Wow, you probably could have abbreviated that a bit.
In any case, your IOS image is hosed. You might have had some bit error during the transfer. At this point you will need to xmodem a new image onto the device. Pleas see this guide (http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
)for more info.
Thank you Mr Gregory
please my switch is c3750x , could you tell me the steps to go to Xmodem  ? please help
The steps are no different than those in the document I linked. I know it says it is for 2950s but the process is exactly the same.
when i do this
Switch: copy xmodem: flash: file name.bin
when i send to Xmodem  , i faced this interrupt ," transfer canceled by remote system !!!!!!!!!!!
please give urgent solution
A few things here:
1. When you put "copy xmodem: flash: file name.bin" you are just using shorthand, and are actually putting in "copy xmodem: flash: [actual name of the IOS image you want to transfer]", correct?
2. Ommit the space after the "flash:", should be "copy xmodem: flash:file_name.bin". Rommon is harsh, there are no real help functions in it and if you get any syntax wrong, the commands will fail.
3. You are starting the xmodem transfer from your PC shortly after you put the command in and selecting a valid image to transfer, correct?
Rawa!
WTF are you doing?????
In your other threads I never recommended 15.2(1)E.
Hi Mr Gregory,
We have Cisco ME-C6524GS-8S switch.We are facing issue with this switch.As we are suspecting issue with IOS.Can you please to resolve this?.I want to know "is the below IOS suitable for the below processor?".Because every day the device is restarted automatically.Hence we are facing issue with network.
e4b-ud-5a#show ver
Cisco IOS Software, s6523_rp Software (s6523_rp-ADVIPSERVICESK9-M), Experimental Version 12.2(20110209:202501) [hpimpalk-NMI_SXI4 100]
This software is supported for a limited time under special agreement with Cisco Systems, Inc. Reference case 616556157
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 09-Feb-11 12:25 by hpimpalk
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
e4b-ud-5a uptime is 8 hours, 39 minutes
Uptime for this control processor is 8 hours, 41 minutes
Time since e4b-ud-5a switched to active is 8 hours, 38 minutes
System returned to ROM by power on at 04:16:03 GMT Wed Dec 18 2013 (SP by power-on)
System restarted at 09:03:14 GMT Sat Dec 28 2013
System image file is "sup-bootflash:s6523-advipservicesk9-mz-eng-special.122-33.SXI4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ME-C6524GS-8S (R7000) processor (revision 1.1) with 458752K/65536K bytes of memory.
Processor board ID CAT103551VT
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
23 Virtual Ethernet interfaces
32 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 256K).
I am expecting your replies ASAP...
Regards, K.RANGARAJ Network Engineer
Ranga,
Your issue is totally different to this thread.
You've created a different thread and I've responded.
Go here.
