IOS-XE 17.6.x Command Reference for command "switchport vlan mapping"?
6502
I have a C9200L switch running IOS 17.6.5.  I am looking for the Command Reference page for the interface-level configuration command "switchport vlan mapping".  I have looked through the indices of serveral IOS-XE 17.x Command Reference guides, but I can't find any references to it.  I know that it's a valid command, as it's accepted on my switch.   Any ideas where I can find it?
Torbjørn
You're right, it does seem to be missing from the command reference... I submitted feedback on it.
It's not the command reference, but this config guide might be useful to you: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-9/configuration_guide/lyr2/b_179_lyr2_9200_cg/configuring_vlan_mapping.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
This is from
Prerequisites for VLAN Mapping
  • By default, no VLAN mapping is configured.
  • Ensure that you run the Network Advantage license. VLAN Mapping is supported only with the Network Advantage license level
Check you lic version
the 17.6 config guides
Layer 2 Configuration Guide, Cisco IOS XE Bengaluru 17.6.x (Catalyst 9200 Switches) - Configuring VLAN Mapping [Support] - Cisco
Regards, Alex. Please rate useful posts.
