IOS XE Denali 16.3.x nmsp interface level commands not available
Dan Coats
I've upgraded from IOS-XE 3.6 to Denali 16.3 and the interface level "nmsp attachment suppress" command is not available (the upgrade removed it from the config) the documentation says it should be available.
Command Reference, Cisco IOS XE Denali 16.3.x (Catalyst 3850 Switches) - Interface and Hardware Commands [Cisco Catalys…
C-Wound-Care-STCK-01#   show run int gi1/1/1
Building configuration...
Current configuration : 250 bytes
interface GigabitEthernet1/1/1
description Connect to MAIN-CORE-7009-01-N7K1 Eth4/24
switchport trunk native vlan 900
switchport trunk allowed vlan 624,900,954,955
switchport mode trunk
channel-group 1 mode active
ip dhcp snooping trust
C-Wound-Care-STCK-01#config t
Enter configuration commands, one per line.  End with CNTL/Z.
C-Wound-Care-STCK-01(config)#int gi1/1/1
C-Wound-Care-STCK-01(config-if)#nmsp ?
% Unrecognized command
C-Wound-Care-STCK-01(config-if)#nmsp attachment supperss
% Invalid input detected at '^' marker.
C-Wound-Care-STCK-01#show ver
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.5b, RELEASE SOFTWARE (fc1)
<snip>
Technology-package                   Technology-package
Current             Type             Next reboot
ipbasek9            Permanent        ipbasek9
cisco WS-C3850-48P (MIPS) processor (revision G0) with 865070K/6147K bytes of memory.
Switch Ports Model              SW Version        SW Image              Mode
*    1 56    WS-C3850-48P       16.3.5b           CAT3K_CAA-UNIVERSALK9 INSTALL
     2 56    WS-C3850-48P       16.3.5b           CAT3K_CAA-UNIVERSALK9 INSTALL
Parthiv Shah
This command (nmsp attachment suppress) is removed from 16.x releases. There was documentation error in configuration guide which points this old information.
Is there any specific reason you need this command or do you want to disable device tracking?
