IOS XE monitor capture issue
Mary
we are using IOS-XE 03.06.04E on switch 3850. I issue below commands:
monitor capture buffer interface G1/0/22 both
monitor capture PCAP match ipv4 protocol tcp any any
monitor capture PCAP start
Please associate capture file/buffer
Unable to activate Capture.
I want to capture G1/0/22 then export to pcap, how to do? thanks
10 Replies 10
Mark Malone
Heres the ios-xe guide for it with examples
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/epc/configuration/xe-3s/asr1000/epc-xe-3s-asr1000-book/nm-packet-capture-xe.html#GUID-7E23C5F6-7BDF-4D18-A208-34FD726D6789
Example: Managing Packet Data Capture
The following example shows how to manage packet data capture:
Device> enable
Device# monitor capture mycap start
Device# monitor capture mycap access-list v4acl
Device# monitor capture mycap limit duration 1000
Device# monitor capture mycap interface GigabitEthernet 0/0/1 both
Device# monitor capture mycap buffer circular size 10
Device# monitor capture mycap export tftp://10.1.88.9/mycap.pcap
Device# monitor capture mycap stop
Device# end
Basic EPC Configuration
  1. Define the location where the capture will occur:
    monitor capture CAP interface GigabitEthernet0/0/1 both
  2. Associate a filter. The filter may be specified inline, or an ACL or class-map may be referenced:
    monitor capture CAP match ipv4 protocol tcp any any
  3. Start the capture:
    monitor capture CAP start
  4. The capture is now active. Allow it to collect the necessary data.
  5. Stop the capture:
    monitor capture CAP stop
  6. Examine the capture in a summary view:
    show monitor capture CAP buffer brief
  7. Examine the capture in a detailed view:
    show monitor capture CAP buffer detailed
  8. In addition, export the capture in PCAP format for further analysis:
    monitor capture CAP export ftp://10.0.0.1/CAP.pcap
  9. Once the necessary data has been collected, remove the capture:
    no monitor capture CAP
http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-embedded-packet-capture/116045-productconfig-epc-00.html
not working in 3850, I don't use any access list, see attached
Did you associate the capture ? can you post some outputs from show commands ?
what license are you on lanbase does not support epc , could be a bug also seems to be a lot of issues with epc on 38s as per doc below not working on multiple versions ios-xe
checked your release open caveats nothing specific for epc bugs though
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/release_notes/OL3262101.html
https://supportforums.cisco.com/document/12013221/using-3850-embedded-wireshark-wired
can you look at my error_pcap.png in above thread, how to assoiciate? both buffer and capture are named PCAP
This is the associate command
monitor capture point associate PCAP PCAP
Dear expert,
monitor capture point associate not workable, see attached
Looking at your config against the 3850 doc theres nothing wrong but your software will just not activate epc, so id say your most likely hitting some bug or its not actually supported on that version of ios-xe
Its asking you to associate the buffer for it to start the epc but the syntax is not even there to do that and in the 3850 doc that's not even a required step to get it working either
This is all that's required as per doc if its not working with that you have a software or platform support issue
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-1/configuration_guide/b_161_consolidated_3850_cg/b_161_consolidated_3650_cg_chapter_0110000.pdf
Step 1: Define a capture point to match on the relevant traffic by entering:
Switch# monitor capture mycap interface GigabitEthernet1/0/3 in
Switch# monitor capture mycap match ipv4 any any
Switch# monitor capture mycap limit duration 60 packets 50
Switch# monitor capture mycap buffer size 100
To avoid high CPU utilization, a low packet count and duration as limits has been set.
Step 2: Confirm that the capture point has been correctly defined by entering:
Switch# show monitor capture mycap parameter
monitor capture mycap limit packets 50 duration 60
Status Information for Capture mycap
Target Type:
Interface: GigabitEthernet1/0/3, Direction: in
Status : Inactive
Filter Details:
IPv4
Source IP: any
Destination IP: any
Protocol: any
Buffer Details:
Dear Experts,
My 3850 is on version: IOS XE 03.06.04.E
below command is use:
monitor capture 1 match any
monitor cap 1int G1/0/32 both
once I enter monitor capture start, it says:
please associate capture file/buffer, unable to activiate capture
on another 3850, IOS XE 03.03.04E also same error
pls help
3650 Version 03.07.02E
same error
how you solved this problem?
llewesc11
Little late to the game on this one, but I just came across the same issue and made it work using the following:
monitor capture PCAP file location flash:/mycap.pcap
