NTP Security Problem
marcio.tormente
Level 6
Level 6
Hello folks!
I receive this message from a company who made a scan my network and they found a problem with the NTP on many switches.
"The remote NTP server responds to mode 6 queries. Devices that respond to these queries have the potential to be
used in NTP amplification attacks. An unauthenticated, remote attacker could potentially exploit this, via a specially
crafted mode 6 query, to cause a reflected denial of service condition."
Anyone knows how can I solve this problem in my switches?
Marcio
Reza Sharifi
Not sure what type of switches you have but if your IOS support it, you can block NTP or allow access from specific NTP server only. Have a look at this document for more info and example:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bsm/command/bsm-xe-3se-3850-cr-book/bsm-xe-3se-3850-cr-book_chapter_00.html
Diana Karolina Rojas
I recommend you apply access groups to your NTP configuration, here and example:
access-list 90 permit X.X.X.X (IP NTP server1)
access-list 90 permit X.X.X.X (IP NTP server2)
ntp access-group query-only 90
That configuration was useful to mitigate the problem in my network.
---Do not forget to rate useful post---
Also I recommend you read this post: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCum44673/?referring_site=bugquickviewredir
^bump
