IOS XE no command "test etherchannel load-balance interface port-channel"?
ivan.yeung
Hi all,
in cisco switch like 3560,2950, there is a command
test etherchannel load-balance interface port-channel X ip x.x.x.x x.x.x.x
to test how the traffic distribute between the etherchannel, however, seem this command is no longer available on IOS XE?
Switch Ports Model SW Version SW Image Mode
* 1 64 C9300-48T 16.8.1a CAT9K_IOSXE INSTALL
2 64 C9300-48T 16.8.1a CAT9K_IOSXE INSTALL
Ivan
the closest command I could find is:
show platform etherchannel channel-group-number {group-mask | load-balance mac src-mac dst-mac
The 'load-balance' keyword tests the EtherChannel load-balance hash algorithm
Google renders another command, not sure if that is actually available:
show platform software fed switch active etherchannel 1 load-balance mac <src mac> <dst mac>
marce1000
 - Check if show etherchannel load-balance can be useful and or check command options available with show etherchannel ?
 M.
