IOSXE Upgrade 3850 - Clean up Flash
Anup Sasikumar
Hey All!
Need your help please,
We are needed to do an upgrade of IOS-XE on a two switch 3850 stack. ( Switch 2 is the master)
We are going from 3.07.3E to the newer 16.3.5b
(Earlier we had done an upgrade from 3.3.4SE to the current version 3.07.3E to support GRE capabilities )
As the newer IOS is a bit heavy around 514MB, I want to make sure we have enough space in flash to copy the IOS and the later installation processes.
Can you please help me to understand which all files are safe to be removed from Flash?
From my understanding , I could safely delete all .pcap/pcapng , txt files , .pkg files of the older 3.3.4 installation.
I have included below the flash ,flash-1 contents.
Please suggest!
Switch Ports Model              SW Version        SW Image              Mode
     1 32    WS-C3850-24S       03.07.03E         cat3k_caa-universalk9 INSTALL
*    2 32    WS-C3850-24S       03.07.03E         cat3k_caa-universalk9 INSTALL
Directory of flash:/
 7754  -rw-     2097152  Nov 23 2017 15:23:34 +00:00  nvram_config
 7747  -rw-    79110340  Apr 23 2015 00:42:06 +00:00  cat3k_caa-base.SPA.03.03.04SE.pkg
 7748  -rw-     6521532  Apr 23 2015 00:42:06 +00:00  cat3k_caa-drivers.SPA.03.03.04SE.pkg
 7749  -rw-    34530288  Apr 23 2015 00:42:06 +00:00  cat3k_caa-infra.SPA.03.03.04SE.pkg
 7750  -rw-    34856268  Apr 23 2015 00:42:06 +00:00  cat3k_caa-iosd-universalk9.SPA.150-1.EZ4.pkg
 7751  -rw-    25172880  Apr 23 2015 00:42:06 +00:00  cat3k_caa-platform.SPA.03.03.04SE.pkg
 7752  -rw-    77445952  Apr 23 2015 00:42:06 +00:00  cat3k_caa-wcm.SPA.10.1.140.0.pkg
 7757  -rw-        1236   Jun 2 2017 15:17:34 +00:00  packages.conf
 7746  -rw-        1216  Jul 28 2017 12:54:15 +00:00  vlan.dat
 7755  -rw-   322991728   Jun 2 2017 11:48:35 +00:00  cat3k_caa-universalk9.SPA.03.07.03.E.152-3.E3.bin
 7756  -rw-        1247  Apr 23 2015 00:42:14 +00:00  packages.conf.00-
54211  -rw-    82022500   Jun 2 2017 15:17:30 +00:00  cat3k_caa-base.SPA.03.07.03E.pkg
54212  -rw-     5653180   Jun 2 2017 15:17:30 +00:00  cat3k_caa-drivers.SPA.03.07.03E.pkg
54213  -rw-    36953096   Jun 2 2017 15:17:30 +00:00  cat3k_caa-infra.SPA.03.07.03E.pkg
54214  -rw-    46236992   Jun 2 2017 15:17:30 +00:00  cat3k_caa-iosd-universalk9.SPA.152-3.E3.pkg
54215  -rw-    28883852   Jun 2 2017 15:17:30 +00:00  cat3k_caa-platform.SPA.03.07.03E.pkg
54216  -rw-   123237184   Jun 2 2017 15:17:30 +00:00  cat3k_caa-wcm.SPA.10.3.130.0.pkg
 7753  drwx        4096   Jun 2 2017 15:35:36 +00:00  virtual-instance
 7758  drwx        4096   Jun 2 2017 15:40:45 +00:00  onep
54209  drwx        4096   Jun 2 2017 15:40:45 +00:00  dc_profile_dir
54217  drwx        4096   Jun 2 2017 15:41:33 +00:00  wnweb_store
 7759  -rw-        7900  Nov 15 2017 13:45:40 +00:00  DHCP.pcapng
 7760  -rw-     4781284  Nov 15 2017 13:27:03 +00:00  CP.pcapng
 7761  -rw-           1  Nov 15 2017 13:10:51 +00:00  output_fed_trace.txt
 7762  -rw-      328711  Nov 15 2017 13:14:36 +00:00  output_fed_trace2.txt
1621966848 bytes total (707416064 bytes free)
Directory of flash-1:/
 7779  -rw-     2097152  Nov 23 2017 15:23:36 +00:00  nvram_config
 7747  -rw-    79110340  Apr 23 2015 00:44:23 +00:00  cat3k_caa-base.SPA.03.03.04SE.pkg
 7748  -rw-     6521532  Apr 23 2015 00:44:24 +00:00  cat3k_caa-drivers.SPA.03.03.04SE.pkg
 7749  -rw-    34530288  Apr 23 2015 00:44:24 +00:00  cat3k_caa-infra.SPA.03.03.04SE.pkg
 7750  -rw-    34856268  Apr 23 2015 00:44:24 +00:00  cat3k_caa-iosd-universalk9.SPA.150-1.EZ4.pkg
 7751  -rw-    25172880  Apr 23 2015 00:44:24 +00:00  cat3k_caa-platform.SPA.03.03.04SE.pkg
 7752  -rw-    77445952  Apr 23 2015 00:44:24 +00:00  cat3k_caa-wcm.SPA.10.1.140.0.pkg
 7759  -rw-        1236   Jun 2 2017 15:17:34 +00:00  packages.conf
 7746  -rw-        1216  Nov 10 2017 13:52:36 +00:00  vlan.dat
 7756  -rw-   322991728   Jun 2 2017 11:48:35 +00:00  cat3k_caa-universalk9.SPA.03.07.03.E.152-3.E3.bin
 7757  -rw-   322991728   Jun 2 2017 11:55:40 +00:00  flash-2
 7758  -rw-        1247  Apr 23 2015 00:44:31 +00:00  packages.conf.00-
15489  drwx        4096   Jun 2 2017 15:35:28 +00:00  vman_fdb
 7760  -rw-    82022500   Jun 2 2017 15:17:29 +00:00  cat3k_caa-base.SPA.03.07.03E.pkg
 7761  -rw-     5653180   Jun 2 2017 15:17:29 +00:00  cat3k_caa-drivers.SPA.03.07.03E.pkg
 7762  -rw-    36953096   Jun 2 2017 15:17:29 +00:00  cat3k_caa-infra.SPA.03.07.03E.pkg
 7763  -rw-    46236992   Jun 2 2017 15:17:29 +00:00  cat3k_caa-iosd-universalk9.SPA.152-3.E3.pkg
 7764  -rw-    28883852   Jun 2 2017 15:17:29 +00:00  cat3k_caa-platform.SPA.03.07.03E.pkg
 7765  -rw-   123237184   Jun 2 2017 15:17:30 +00:00  cat3k_caa-wcm.SPA.10.3.130.0.pkg
 7753  drwx        4096   Jun 2 2017 15:35:28 +00:00  virtual-instance
23233  drwx        4096   Jun 2 2017 15:37:43 +00:00  dc_profile_dir
30977  drwx        4096   Jun 2 2017 15:38:19 +00:00  wnweb_store
 7766  -rw-     1008664  Sep 15 2017 10:34:21 +00:00  dhcpcontrol.pcap
 7767  -rw-        1098  Sep 15 2017 10:55:26 +00:00  dhcpgi107.pcap
 7768  -rw-      919310  Sep 15 2017 11:21:39 +00:00  dhcpgi6control.pcap
 7769  -rw-      957282  Sep 15 2017 12:11:32 +00:00  finaltest.pcap
 7770  -rw-       27821  Sep 15 2017 12:12:08 +00:00  finaldebugs.txt
 7771  -rw-      901380  Oct 17 2017 10:33:32 +00:00  Gi102-1017.pcap
 7772  -rw-      742220  Oct 17 2017 10:55:31 +00:00  Gi102-1017-2.pcap
 7773  -rw-     1523962  Oct 17 2017 11:20:34 +00:00  Gi108-1017-3.pcap
 7774  -rw-     2497764  Oct 26 2017 08:06:59 +00:00  dhcpcop.pcap
 7775  -rw-    10002163  Oct 26 2017 08:07:44 +00:00  dhcpdebugs.txt
 7776  -rw-     1160190  Oct 26 2017 08:41:32 +00:00  dhcpcop2.pcap
 7777  -rw-    10002163  Oct 26 2017 08:42:20 +00:00  dhcpdebugs3.txt
 7778  -rw-     2497764  Oct 26 2017 14:57:32 +00:00  usbflash0-1
 7755  drwx        4096  Nov 10 2017 13:51:51 +00:00  onep
1622147072 bytes total (357040128 bytes free)
Anup
17 Replies 17
The filenames listed in the flash directory have 16.3.9 in the file name. What do you mean not related to 16.3.9?
That was a type-o.
I meant I'm seeing all 16.3.9 files so you've cleaned out the old files.
fedor.solovev
You may boot from FTP.
