01-26-2016 12:24 PM - edited 03-08-2019 03:32 AM
My production asr IOS XE software is
asr1001-universalk9.03.13.04.S.154-3.S4-ext.bin
For a IPV6 vulnerability I researched and found this "fix code"
asr1001-universalk9.03.17.00.S.156-1.S-std.bin
I am using the adventerprise license
Could someone help me understand the difference between ext.bin and std.bin
Solved! Go to Solution.
01-26-2016 12:49 PM
Haven't used IOS XE but I believe it designates whether the version is standard support or extended support with extended support being an IOS version that Cisco will support for an extended time period.
See this link which gives more details -
note also the recommendation is, if possible, to use an extended version.
Jon
01-26-2016 12:49 PM
Jon
01-26-2016 01:29 PM
Jon thanks much for your help
