IP-6-PHYBCASTDROP
Ibrahim Jamil
Level 7
Level 7
i have the below msg appear on my 6500 , what is the reasons and how to sove it
%IP-6-PHYBCASTDROP: Physical broadcast packet detected and dropped,
thanks
11 Replies 11
Raju Sekharan
Hi Ibrahim
1. As per RFC  standard 1812 section 5.3.4,
A router SHOULD silently discard a packet that is received via a LinkLayer broadcast but does not specify an IP multicast or IP broadcast   destination address.
http://tools.ietf.org/html/rfc1812#section-5.3.4
You have received such a packet and router has dropped
2. 169.254.X.X IP range is not a routable IP range. it is reserved range for link-local addressing in Internet Protocol Version 4.
Some of your host has got this IP becasue it didn't receive DHCP IP address and it got this range of I Pas part of microsoft auto-ip
3. If you are receving these messages frequently, then you need to locate the host sending this broadcast
Thank you
Raju
Hi Raj
Thanks for ur reply
How to locate the host sends this brodcast?
thanks
ibrahim
Hi Ibrahim,
You can try capturing the packets with mac-address ffff.ffff.ffff and find out he source mac of those packets to locate the host
Is the error message showing any IP address?
Raju
Hi raj
how do i do that?the mac is 169.254.x.x?pls help me out
thanks
ibrahim
Hi Ibrahim,
is your error message showing the MAC address from the packet is coming?
If it is not showing, we have the following options
Oneway is to use Miniprotocl Analyzer to  capture the packet if your IOS supports it. You can filter using an ACL which matches source IP address 169.254.X.X
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SY/configuration/guide/mini_protocol_analyzer.html
There is an easy way if you have only few subnets. Just configure s secondary IP address of 169.254.X.X/16 on your interface. Then give a ping to 169.254.255.255. If you get a reply from any of the host look in the ARP table
show ip arp | inc 169.254
This will show the mac-address of the host. Which you can track
You need to do this on interfaces one by one till you find the host sending this packets
Raju
Hi raj
thanks for ur reply
below is the error msg
src=169.254.61.133, dst=169.254.255.255
thanks
ibrahim
What is the version of code you are running?
Raju
Also provide the following output
1. Show module
Raju
Hi Raj
thanks for ur reply
pls find below info
(s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI2a
1   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  2   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  3   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  4   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G
  7  48  CEF720 48 port 1000mb SFP              WS-X6748-SFP
thanks
Hi Ibrahim,
You can do an ELAM to capture this packet
do the following setps
1. test platform service internal enable
2. sh pl ca elam asic sup slot 5
3. sh pl ca elam tri dbus ipv4 if IP_SA=169.254.61.133
4. sh pl ca elam start
Once you get the error message check if ELAM captured the packet
5. Sh pl ca elam status
it will show as completed once it captures the packet
6. Sh pl ca elam da
This will show the packet with source-mac
After this you can track the mac-address and find out where it is connected
Disable the ELAM after you are done
7. test platform service internal disable
Raju
Hi Raju
thanks for ur reply
