Ip accounting on Cisco 4500
I'm looking for ways to enable ip accounting on my core 4500, but no all the commands are available as show in the document Cisco website:
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_ipserv_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055346
Example configuring my switch (There´s no options for accounting in the interfaces.):
CORE_1(config-if)#ip ?
Interface IP configuration subcommands:
  access-group  Specify access control for packets
  admission     Apply Network Admission Control
  arp           Configure ARP features
  auth-proxy    Apply authenticaton proxy
  dhcp          Configure DHCP parameters for this interface
And when i execute the command show ip accounting, the command is executed OK but there´s no information to show.
I have checked the Cisco Feature Navigator Tool and supposedly the IOS version that I have already supports the functionality of IP Precedence Accounting, that´s the show version, where the ios is: 12.2(37)SG1
CORE_1#    show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Ve
rsion 12.2(37)SG1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Jul-07 14:22 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11742458
ROM: 12.2(31r)SG3
Pod Revision 14, Force Revision 31, Tie Revision 32
CORE_1 uptime is 11 weeks, 1 day, 6 hours, 58 minutes
System image file is "bootflash:cat4500-entservices-mz.122-37.SG1.bin"
cisco WS-C4506 (MPC8540) processor (revision 11) with 524288K bytes of memory.
Processor board ID FOX104308NB
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
3 Virtual Ethernet interfaces
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Any idea?
Message was edited by: operaciones_redes
Fabienne Stephanoff
IP accounting is currently not supported on the 4500. You can use a netflow feature card alternatively:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_19/config/nfswitch.htm
Fab.
thanks!! ill test it
