Ip accouting + 4507 R switches....
smothuku
Level 7
Level 7
Hi ,
Is there any way to enable ip accouting on gig (EoSDH link is terminated between Site A and site B) of 4507 R switches...
Site A (Gig 3/45) -- EoSDH link -- (G3/45)Site B.
I want to analyze the traffic which is traversing through 10 Mb EoSDH link between site A to Site B and vice-versa.
I heard that 4507 R switches doesn't support ip accounting
Satish
Jon Marshall
Satish
You are right, the 4500 does not support IP accounting. The solution for this platform would be to use NetFlow but that does depend on whether you have the Netflow daughter card on your supervisor.
Which supervisor are you running ?
Jon
