IP address not visible in CDP detail
ziqex
Level 4
Level 4
Hello everyone,
I have encounter the following issue.
Two switches connected via trunk on the same native vlan.
Switch A after running cdp neighbour detail:
SW-GF-08#sh cdp neighbors detail
Device ID: SW-PTC-01
Entry address(es):
Platform: cisco WS-C3850-48P, Capabilities: Switch IGMP
Interface: FastEthernet0/8, Port ID (outgoing port): GigabitEthernet1/0/46
Holdtime : 136 sec
Version :
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.6.6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 11-Apr-19 02:24 by mcpre
advertisement version: 2
VTP Management Domain: ''
Native VLAN: 998
Duplex: full
port config switch a
interface FastEthernet0/8
switchport trunk native vlan 998
switchport mode trunk
switchport nonegotiate
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
spanning-tree guard root
port config switch b
interface g1/0/46
service-policy output PER-PORT-QUEUING
Any advice would be highly appreciated.
Thank you.
After connecting the client the management vlan status changed to up/up and the IP address is visible in the cdp neighbours detail. No configuration changed was completed.
Reza Sharifi
You need to have an SVI on each switch to be able to see the IP
interface vlan 998
ip address x.x.x.x
in addition to Reza's post, (obviously) make sure that Vlan 998 exists on both switches. When you do a 'sh ip int brief' the status of Vlan998 should be up/up on both switches...
If the Vlan does not exist, you need to create it:
SW-GF-08#conf t
SW-GF-08(config)#vlan 998
SW-GF-08(config-vlan)#end
SW-PTC-01#conf t
SW-PTC-01(config)#vlan 998
SW-PTC-01(config-vlan)#end
the management VLAN needs to be up/up indeed (just like any iinterface actually) for the IP address to become active...glad that you got it resolved.
