Cisco c6832-x-le
Umar
Hi guys,
My name is umar , In my network i have an aggregation c6832-x-le and the access switch connected to it via FEX is c6800IA and if i want to change any thing in configuration i change it at aggregation and access switch sync. its configuration from aggregation via FEX so i want to know that which series of switches i can use with c6832-x-le.
For example can i connect 2960 series switch with c6832-x-le or not and how to find the which series of switches is compatible with c6832-x-le?
balaji.bandi
c6832-x-le - is fixed switch with 16/32  x 10G SFP native
As long as you have 2960 with uplink module with that capacity you can connect to the switch. ( ro any switch model can support that capabilities can work with your switch)
But you need to configure 2960 - unlike FEX.
BB
