IP ADDRESSING
mdmaqdoom
Frequent Visitor
Frequent Visitor
I  want to block some ip on my network,
this IP are primary IP in my Network (Some Devices has a default IP's i have many vendor devices that has same IP binded i want to Block on my network)
One Devices is connected on FA2/5 (IE 115 Switch ) other devices is connected on 2960X (Gi1/2/20)
kindly please suggest the command (it can done by IP access list) please give the complete command
thanks
Maqdoom.M
Seb Rupik
Hi there,
I suggest you look at DHCP snooping and IP Source Guard.
Assuming all of your devices use DHCP; dynamic allocation or static assignment, then any device which appears on the network trying to use an address not received from your DHCP server will have its traffic discarded.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/security/configuration_guide/b_sec_3se_3850_cg/b_sec_3se_3850_cg_chapter_01101.html
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
i like that idea; DHCP snooping and IP Source Guard, plus possible to add ARP inspection
kudos!
Can do some with ip access list
plz suggest I wo not have any dhcp on my network only I have two swithces interface from where my vendor IP are connected I need to block this ip
I was doing as per your suggestion but on the same interface I have two ip one Mac I cannot block the mac but only the bindded ip of vendor specified
this also I can achieve On firewall or router by doing NAT but cannot afford the router for one ip devices
any alternate plz suggest
regards
maqdoom
