IP Base versus IP Services
bschol
Frequent Visitor
Frequent Visitor
Dear All,
I am always struggling what is supported in which version.
Is Inter VLAN routing a standard feature of IP Base or do I require IP services. ?
Currently using C2960S (IP Base) ; do I require other platform.?
Is there a good overview (document or link), where this is explained.?
Thanks very much,
Regards Bert Schol
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Features vary between platforms and sometimes even IOS versions for feature packages.  It depends whether the features you need are in the feature set for your platform.
The feature navigator tool can show what differs per platform and IOS.
