IP Base vs LAn BAse options in switches
Risaboke2008
what is the difference IP Base vs LAN BAse options in switches? why should i choose either type
Use IP Base if you need basic routing (L3) and use LAN Base if you need L2.
The differences are explained in the Q&A of the product pages. Here an example for a 3850:
http://www.cisco.com/go/3850 -> Q&A
