ip based vs lan based layer switch
hello all,
what is the difference between an ip base and a lan based layer 3 switch?
what is ip based? how does it work?
what is lan based? how does it work?
thanks
paolo bevilacqua
Please point out where in Cisco documents you have seen these terms.
http://www.3anetwork.com/cisco-catalyst-3560-switches-price_c40
i was just wondering what is ip based and ip lan based switch
Jan Hrnko
Level 9
Level 9
These are different IOSes that have different sets of commands and features available. You should check, what kind of image do you need for your purposes. Try to use some of these tools:
http://tools.cisco.com/ITDIT/CFN/
Best regards,
Jan
