IP binding
Hi all,
I would like to know about setting up management access to network infrastructure devices.
Using my home test network, I have my Cisco router and my switch on the same management subnet.
For convenience, I want to block management access from all but my Android phone (running ssh client) and laptop connected by WiFi access point plugged into the router and on a home appliance / wireless access vlan.
Should I do this by binding the router leased IP addresses for these devices to their MAC address so I know their IP won't change, and then add these IPs to a permit ACL?
I know this isn't going to be best practice, but is this the way to achieve what I would like, or is there a better way?
Also in general, when should you bind IP to MAC and when should you manually give a device a static IP?
Thanks.
You can apply the access list per host if you don't want allow everything in that subnet.  For example: the access list below allows access from hosts 192.168.1.15, 16, 17 and nothing else.
access-list 50 permit host 192.168.1.15
access-list 50 permit host 192.168.1.16
access-list 50 permit host 192.168.1.17
and so on.....
Reza Sharifi
If you want only certain ip range to access the network devices, then you can simply allow that subnet.
In this example, your phone, laptop and Wifi are all in 192.168.1.0 subnet.
Create the access list
access-list 50 permit 192.168.1.0  0.0.0.255
then apply it to the vty line
line vty 0 4
access-class 50 in
and test
Thanks for the reply, but that would only block access to the management of the router, and not the other devices in the management vlan.
and so on.....
I'm not sure you understand me.
I want to control access to all devices in the management vlan, not just the Cisco router.
