IP Confict Issues
zahidlegend786
Community Member
Hi Guys,
Need some help
Our core switch is setup with DHCP server
We are suddenly having a problem where static IP's which are assigned to printers are being taken by PCs randomly
This has not been a problem in the past and has suddenly started. However there are no IP conflict errors on the switch which is weird
thanks in advance
Richard Burts
The symptoms that you describe suggest that addresses are not correctly reserved in DHCP for the printers. It would be a good start if you would post the part of the config that relates to DHCP, and even better if you would post the complete config.
Rick
Rick
