IP connectivity between Nexus and Palo Alto firewall
jeff20
I'm struggling to understand connectivity problem between a switch and firewall.  The Nexus is located between the Core switch and the edge firewall. It's purpose is to divert traffic via ITD for content filtering.  My problem right now is that I'm not able to ping from the Nexus to the Palo Alto. Both interfaces have an IP in the same network.
When there is an IP on the Cisco side L3 interface the IP ARP looks like below.  I'm trying to ping 164.104.10.1 connected to Ethernet 1/1.  I can ping it if there is no IP configured on the Cisco interface, but when I put 164.104.10.2 on it, I can't ping and see the INCOMPLETE in the table.
IP ARP Table for context default
Total number of entries: 9
Address Age MAC Address Interface Flags
10.112.11.2 00:16:29 3cec.effa.dc98 Vlan3
10.112.11.3 00:16:29 3cec.ef62.a318 Vlan3
10.112.11.4 00:16:29 3cec.effa.dc1a Vlan3
10.112.11.5 00:16:29 3cec.effa.dc48 Vlan3
10.112.11.6 00:16:29 3cec.effa.dc88 Vlan3
10.112.11.7 00:16:29 3cec.effa.8eea Vlan3
10.112.11.8 00:16:29 3cec.effa.db5c Vlan3
164.104.10.130 00:03:10 8030.e0ba.a600 Vlan1
164.104.10.1 00:00:10 INCOMPLETE Ethernet1/1
29 Replies 29
Cisco_iBoss_switch# show ip interface brief
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan1 164.104.10.129 protocol-up/link-up/admin-up
Vlan3 10.112.11.1 protocol-up/link-up/admin-up
Eth1/1 164.104.10.2 protocol-up/link-up/admin-up
there are two IP in same subnet hop you use different mask ? VLAN1 and Eth1/1
MHM
jeff20
Yes, those are both using a /25 mask.
NSK# show ip adjacency 164.104.10.1 detail | b default | grep –v ^$
share the output of above
jeff20
I'm not able to add the grep part of the command...
Cisco_iBoss_switch# show ip adjacency 164.104.10.1 detail | b default
IP Adjacency Table for VRF default
Total number of entries: 1
Address : 164.104.10.1
MacAddr : 0000.0000.0000
Preference : 255
Source : arp
Interface : Ethernet1/1
Physical Interface : Ethernet1/1
Packet Count : 0
Byte Count : 0
Best : No
Throttled : No
Active/passive FW in cisco abd  I think it same in Palo
Both FW interface use same subnet'
But the Sw that connect to is not use L3 port it use VLAN SVI
And here is your issue
Make two port connect to both FW in one VLAN' assign IP to this VLAN
That it
It design issue
MHM
Okay, thank you.  I understand why that would be a better design.
it not better or not
it work or not
MHM
jeff20
Understood, and it would look like this, correct?
jeff20
It's at that location in the topology because of ITD needed for iBoss content filtering, which we can't run on our core HPE switch.  The default 0.0.0.0/0 route on the core switch points to 164.104.10.129 on the Cisco, then ITD redirects some traffic by means of ACLs in and out of the iBoss filter.  Then the default route to the Internet on the Cisco points to 164.104.10.1.
JFYI
I am unfamiliar with iBoss, but I know you can do all your content filtering on the PAs with the right license.
Exactly right, and that would be my preferred solution to this issue.
jeff20
As of now the original "asymmetric" design is functioning by means of manual re-configuration of the 0.0.0.0/0 route on the Core switch, along with manual clearing of the ARP table on the Core and the Cisco.  Re-design of this segment is planned to provide hands-off resiliency as suggested in this thread.  Thanks for the help!!
You are so welcome'
For my the only solution is re-design
MHM
