04-29-2024 07:22 AM
Hi all,
I'm configuring a 9200L switch to be a spare, just with its management interface Gi0/0 configured. It's up and running, and I can login using a local account. However radius is not working, it seems that the switch is unable to contact the radius servers:
004408: *Apr 29 11:19:33: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.10.10.22:1812,1813 is not responding.
004409: *Apr 29 11:19:49: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.10.10.30:1812,1813 is not responding.
004410: *Apr 29 11:20:05: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.10.10.50:1812,1813 is not responding.
004411: *Apr 29 11:20:05: %RADIUS-3-ALLDEADSERVER: Group ISE_GRP: No active radius servers found. Id 6.
I tried adding the ip radius source-interface global command and inside the AAA group, no luck. Any idea or references will be appreciated.
Thank you,
LeoC.
Solved! Go to Solution.
04-29-2024 08:01 AM
It finally worked, with this config:
aaa group server radius ISE_GRP
server name ISE_SRV1
server name ISE_SRV2
server name ISE_SRV3
ip vrf forwarding Mgmt-vrf
deadtime 10
Thank all for your guidance!
LeoC
04-29-2024 07:27 AM
Share the config of SW AAA and radius server
MHM
04-29-2024 07:29 AM
how is your configuration looks like for the gig 0/0
is that in VRF mgmt ?
ip radius source-interface xxx
also try to ping radius using sourcing that interface?
Quick question is this TACACS or Radius (802.1X) ?
04-29-2024 07:46 AM
@MHM Cisco World and @balaji.bandi Here is the AAA config. Radius (via ISE) is used for authentication and authorization.
SPARESw01#sh run aaa
aaa authentication login default local group ISE_GRP
aaa authentication login netctrl group ISE_GRP local
aaa authorization exec netctrl group ISE_GRP local
aaa authorization network default local group ISE_GRP
username xxxx privilege 15 password yyyy
radius server ISE_SRV1
address ipv4 10.10.10.22 auth-port 1812 acct-port 1813
timeout 5
retransmit 3
key xxxx
radius server ISE_SRV2
address ipv4 10.10.10.50 auth-port 1812 acct-port 1813
timeout 5
retransmit 3
key xxxx
radius server ISE_SRV3
timeout 5
retransmit 3
key xxxx
ip radius source-interface GigabitEthernet0/0
deadtime 10
aaa new-model
aaa session-id common
ip radius source-interface GigabitEthernet0/0 vrf Mgmt-vrf
SPARESw01#sh run int gi0/0
Building configuration...
Current configuration : 128 bytes
description Management OOB
ip address 10.1.1.240 255.255.255.0
end
SPARESw01#sh run | i route
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 10.1.1.1 permanent name Default_OOB
SPARESw01#ping vrf Mgmt-vrf 10.10.10.22
Sending 5, 100-byte ICMP Echos to 10.10.10.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
The line "ip radius source-interface GigabitEthernet0/0" under the AAA group is the last I added to test, no luck.
04-29-2024 07:48 AM
04-29-2024 08:01 AM
deadtime 10
LeoC
