ip dhcp snooping
fd_case17
I used this feature in a previously switched network ( one vlan)
Now , my network looks like several vlans with a 3750 who acts as the hub and makes routing for vlans ( with SVI and ip helper address) , the dhcp server is in a specfic vlan .
How can I configure dhcp snooping for this,
cause my clients never get dhcp offer from the server,
I simply make this on an access swith :
ip dhcp snooping
ip dhcp snooping vlan 10 !vlan access
ip dhcp snooping trust ! for uplink trunk
thanx
cisco_lad2004
Level 5
Level 5
Fab,
Your configuration looks correct!
1-Enable DHCP snooping.
2-Apply it to selected VLANs.
3-Exclude physical port / trust the legitim DHCP server.
If your set up still does not work, check routing from SVI to server and vice versa.
Sam
