IP DHCP Snooping
Andrew White
Level 2
Level 2
i have enabeld DHCP snooping on a switch:
ip dhcp snooping vlan 10
ip dhcp snooping
Then plugged in a Cisco router (fa 0/2) that has a DHCP scope and then did an "ipconfig /release" then "ipconfig /renew" and the laptop doesn't get an IP, great.
However the table shows nothing, should I see fa 0/2 as trusted = no?
Switch#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
   circuit-id default format: vlan-mod-port
   remote-id: 0022.0db8.2c00 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
Switch#
cadet alain
No, by dfefault all ports are untrusted and you should put the uplink interfaces to valid DHCP server as trusted with the interface command ip dhcp snooping trust
Alain
How can I find out if a rougue DHCP server is ever installed?
