IP DHCP SNOOPING
dacruzer1
Ladies and Gents,
I am thinking about enabling "ip dhcp snooping" on my 3750G switches and was reading through all the options:  .   I want the option that will protect my network from dhcp snooping but I'm not sure which option to enable.  I am running VLANs on all my switches.  If theres anyone out there that has done this before, I would appreciate it.
Alfred
acampbell
Alfred,
Here is a config that turns on DHCP snooping.
The DHCP server is on interface G1/0/10 and this is the only trused port.
All other ports are untrusted therefore DHCP responses like DHCPOFFER from untrusted ports are dropped.
You can read all about DHCP snooping in the config guide.
Here the link to IOS ver 12.2.55SE:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swdhcp82.html#wp1058138
config t
ip dhcp snooping
ip dhcp snooping vlan 3-6,10-20
interface g1/0/10
description MY DHCP SERVER
ip dhcp snooping trust
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Alfred,
config t
ip dhcp snooping
interface g1/0/10
Alex.
Hi Alex,
Thanks mcuh for the info.  I have enabled per your config.
What about clients on the same switch, do I need to enable "ip DHCP snooping trust" also?
Alfred
Alfred,
In short NO
You only trust the interfaces that connected the DHCP servers.
Alex.
Alex,
Thansk again!
Alfred
