ip directed-broadcast and acl
kp-tkr2014
Hi friends ,
access-list 102 permit udp host 192.168.80.10 any eq 7
ip directed-broadcast 102
1 ) Why we do not need to specify a direction ( in or out )  when an access list associated with  directed-broadcast ( ip directed-broadcast 102) command .
2) if there is  an existing  access-list as  below  ,
Interface vlan 100
Ip add 10.0.7.2 255.255.255.0
ip access-group testing  out
Q. W hat is  the processing order of the access-list
Q .Can club the access list ?
Q.if  i cannot club the access list  do i need to  add  the line  (permit udp host 192.168.80.10 any eq 7 ) again  in the access list 'testing '
10 Replies 10
1) i would say the order is made though the ACL where define src and dst
2)I do not understand really..
  • ACL process oder top to button
  • what does that mean "club" u mean combine I would say maybe depends on what u want achive
  • testing is another ACL than 102,why does the ACL make sense on anSVI with a 10.x when u configure a 192 in the ACL
Richard Burts
To answer your questions
1) you do not need to specify a direction when using an access list with directed broadcast because directed broadcast is, by definition, about incoming traffic.
2) the other access list that you give in the question is an outbound access list. Since directed broadcast is inbound and the other access list is outbound they operate independently and do not influence each other. The order of processing is that the inbound directed broadcast list is used to evaluate inbound traffic and the outbound list is used to evaluate outbound traffic.
I do not understand what you mean when you talk about club an access list.
I think that the question that you were trying to ask is about whether if there were an inbound access list would you need to repeat the same line from the directed broadcast access list. No not necessarily. You do not have to repeat the statement, but you do need to be sure that the inbound access list would permit the incoming packet that is the directed broadcast packet.
So if the access list in does not permit the broadcast packet then it does not matter whether access list 102 permits it or not since the packet will be dropped. So for the incoming directed broadcast to work it must be permitted in the inbound access list (like test) and also permitted in the directed broadcast access list (like 102).
Rick
Rick
Hi Rick
" 1) you do not need to specify a direction when using an access list with directed broadcast because directed broadcast is, by definition, about incoming traffic. " .
(access-list 102 permit udp host 192.168.80.10 any eq 7)
Interface vlan 100
 As per the above access list the source ip is  (192.168.80.10) .  If  the direction is 'in' , the source will not match and the ACL will simply  drop  the traffic from 192.168.80.10 .  To match the source ip, the ip  must be  one from the  interface vlan subnet ( 10.0.7.0 /24).
Please correct me i am wrong
2 ) What is the difference between the below lines .
permit udp host 192.168.80.10 eq 7 any
Thank you
I can not correct you because you are not wrong. I should have been more careful about how I phrased my response and if you take my response literally then my response was wrong. What I meant to express is that the access list used for directed broadcast is about traffic coming into the router from somewhere and being sent out the interface on which the directed broadcast command is configured. There is an inbound component because the access list is examining source addresses. But the traffic that the access list is controlling is outbound. My mistake and I apologize.
2) (being more careful this time) the first example is checking for 7 to be the destination port in the traffic while the second example is checking for 7 to be the source port in the traffic.
Rick
Rick
Hi Rick
When  you said incoming traffic , i thought  you are talking about  the direction 'in'.
Apologize and  thanks for your great  help .
I have one more question ,
the server use an apps which uses some random port (for example 62577)   and  sending udp packets to the destination port  7
if  i am writing  an access list with 'out'  direction , how it would be like ?
if my server is 192.168.80.10  the  below access list is ok ?
ip access-list extended test2
  permit udp host 192.168.80.10 any eq 7.
I am sorry that my original response was not more clear and accurate. It would have been better if I had said that it was outbound.
In your question the 62577 is the source port from the server? There is no requirement to specify the source port in your access list and the test2 list that you show should work fine specifying the source IP address and the destination port.
Rick
Rick
Hi rick
I had no luck  with the above access list , wireshark capture from the server 192.168.80.10 shows  source port  62991 and destination port is 7 (attached image) .
When i change the access list as below it did work .
permit ip host 192.168.80.10  any
Please help
I am a bit puzzled if the access list did not work. The capture clearly shows that it is a UDP packet with destination port of 7. So I would have thought that the access list
should have worked. Perhaps you can tell us where you applied the access list and how you applied it?
Rick
Rick
Hi Rick
Here is my access list and other configuration
ip access-list extended testing
and there are other lines , its a long list
 permit ip any any
interface vlan 100
ip helper-address 192.168.1.20
"I just added  102  with ip directed-broadcast command even it does not make any sense since there is an ACL (testing ) already there on the  interface "  .
I am not sure that I understand what is going on here. But let me try to clarify one aspect of this discussion - the relationship of the access list used in the directed broadcast command and the access list applied to the interface. The access list applied to the interface using ip access-group examines and controls what packets are sent out the interface. The access list used in the directed broadcast command does not control what is sent out the interface. In that sense perhaps my initial reluctance to describe this access list as outbound was justified.
So if the access list in directed broadcast does not control outbound packets what does it do? In trying to explain that let us be clear how directed broadcast works and take the logic a step at a time. A directed broadcast is forwarded through networks just like a unicast packet. No router forwarding the packet can be sure whether it is a directed broadcast or not. Only the router connected to the destination LAN can be sure whether it is a directed broadcast or not.
So when the directed broadcast packet gets to the destination what does the router do? After the router determines that the packet is a directed broadcast it checks to see whether directed broadcast is enabled on that interface. (by default directed broadcast is disabled - so if you want it you must enable it) If the router determines that directed broadcast is enabled it then checks to see whether this particular directed broadcast should be forwarded. It does this by checking the access list (if an access list is configured) If the router determines that this particular directed broadcast should be forwarded it transforms the packet into a broadcast (I found one description of this which uses the term "explodes" the packet into a broadcast, which is an interesting way to describe it). So the function of the access list in directed broadcast is to control whether the packet is to be transformed or not. It is not a control over whether the packet is transmitted (like the interface access list is).
I hope this helps to clarify the difference between the access list applied to the interface (does control sending outbound traffic) and the access list applied to directed broadcast (does control the conversion of the packet into a local broadcast).
Rick
Rick
