ip directed broadcast
avilt
Level 7
Level 7
My management vlan on a L2 switch is 172.16.0.0/24.
I have added the  command "no ip directed broadcast" on the vlan interface.
But when I ping from a client PC to the broadcast address 172.16.0.255 the switch responds to this address.  How can I disable this?
2 Accepted Solutions
ip access-list extended no-dbc-ping
  deny icmp any host 172.16.0.255 echo
  permit ip any any
interface F0/0
  ip access-group no-dbc-ping in
Unfortunately you cannot do this as the corresponding outgoing ACL because outgoing ACLs do not affect packets generated by the router itself.
Kevin Dorrell
Luxembourg
Kevin is right.
Anyway, as I wrote already, if you don't want your switch to reply to directed brodcasts you need to prevent them from entering to the management subnet at all... and how you do that? By configuring 'no ip directed broadcast' on the last L3 device routing traffic into 172.16.0.0/24 subnet.
On the contrary any device will reply to local broadcasts as they are forced to do so.
Riccardo
6 Replies 6
rsimoni
you need the command on the last L3 device routing traffic into 172.16.0.0/24 subnet.
The command prevents a router from sending traffic to directed brodcast address not a device from replying to it.
Riccardo
How can I prevent the end device from responding to the broadcast address?
  permit ip any any
interface F0/0
Kevin Dorrell
Luxembourg
Kevin is right.
Riccardo
So with this command the L3 device will not forward/move the traffic to the broadcast address from a remote system to its directly connected subnet right?
So if I have a L3 device, is it advisable to put this command on all vlan interfaces?
rsimoni
yes and yes (unless you need local brodcasts of course)
