IP Duplication issue on all vlan
tarunavakonar
Plz find the error message
*Oct 15 08:26:19: %IP-4-DUPADDR: Duplicate address 10.205.124.2 on Vlan6, sourced by 0009.6b99.982e
Plz reply on urgent
6 Replies 6
tarunavakonar
plz reply
Error Message
%IP-4-DUPADDR : Duplicate address [int] on [chars], sourced by [sci_notation]
Explanation Another system is using your IP address.
Recommended Action Change the IP address of one of the two systems.
Reference:http://www.cisco.com/en/US/docs/ios/12_0/system/messages/emflash.html#wp1026166
Check to see if you have another network devices with the same mac address.
I hope this helps.
Best regards.
Massimiliano.
no
is there any another issue is possible
it is happening on every vlan's gateway address
have you looked at what device is triggerign the message (based on hardware address)
sometimes came from switch, some time from pc
we are using cisco 4506
Is there any DHCP configured ?
If so you may need to check the settings and reduce the lease time
Hope this helps
