ip-helper using SNMP
tonyp8581
Level 4
Level 4
Can I get the ip-helper information using SNMP. I've looked around, I can't seem to find the OID number.
Yudong Wu
Level 11
Level 11
this is a old MIB, not sure if it is still there. And if you have multiple ip helper configured under the interface, it can only return one of them.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=OLD-CISCO-IP-MIB
Hi kwu2,
Unfortunately, the OID found on the link returns an error.
Thanks for your quick response. If I find anything, i'll post it.
