ip helper
felix.mugambi
Hello guys, do we have ip-helper configuration on meraki switches?
6 Replies 6
jroegner81
Community Member
Hi Felix,
click on Switch --> Configure --> Routing & DHCP
Then click "Create an interface" Even on a L2 Switch you can create an interface in the VLAN you need and configure a DHCP Relay address.
Johannes
MarcP829
Level 9
Level 9
Should only be possible in MX´s
@jroegner81 is correct. Possible in both MX and MS's (L2 and L3 models). For the switches it's called DHCP relay in the specs.
Dave_S1
Community Member
But do you need to enter in an interface IP and, if so what exactly is it looking for?
For the MS - It's looking for an interface in the subnet/VLAN you want to listen for DHCP requests in, and will then relay those requests (using the interface's IP), to the DHCP servers it's configured to relay to.
Dave_S1
Community Member
So, for example, I have 3 VLANS called VLAN 100, 140 & 150, with IP addresses of 172.28.100.x, 172.28.140.x & 172.28.150.x. My DHCP server is in VLAN 51 at 172.28.51.x, and the switch is on mgmt VLAN 31 or 172.28.31.x. For the Routing and DHCP, do I create in interface in each of the vlans, so like 172.28.100.5, 172.28.140.5 & 172.28.150.5 for example pointing to my DHCP server, or would I just use 1 IP for all interfaces in the switch's VLAN 31, forwarding DHCP requests tagged with the VLAN ID to the DHCP server?
