IP in IP and NAT
Nav Sangha
I am just wondering if this is possible, i have a setup as below.
R1 Public IP ---internet------Public IP ASA Private IP-----------Private IP R2
This Cisco ASA has a 1 to 1 NAT setup to translate R2 Private IP to a Public IP in both directions.
Would it be possible to setup a IP in IP tunnel between R1 and R2 or will this not work?
6 Replies 6
 Could you reformulate you question ?
"Would it be possible to setup a IP in IP tunnel between R1 and R2 or will this not work?"
What do you mean by IP in IP ?
Hi, similar tunnel to GRE but IP in IP, aka IP in IP encapsulation
Got it.
With One-to-One NAT I believe is possible.
Very good explanation Here
Any chance of doing this without ipsec, to get the throughput that IPIP encapsulation gives with my current router i would need to buy a bigger router if i had to use ipsec.
I think so. That was just one possible scenario. If R1 can reach R2 and the NAT in the meddle is One-to-one, I don't see why not.
 I'll try that on lab later on.
Thanks for that, other way around i assume is to put the ASA into transparent mode and forget the NAT, never setup an ASA in this way though.
