Showing results forĀ
Search instead forĀ
Did you mean:Ā
ip load-sharing per-packet command on catalyst 3850
tetsuo.kawakami
I would like to confirm if or not Catalyst3850 with IOS-XE 03.07.05E supports  "per packet load sharing".
If anyone let me know how to make sure about it, I would appreciate very much.
Thank you.
Joseph W. Doherty
Probably not (sorry, I really don't know for sure), but even if it did, per packet load-sharing is often a poor idea (because although per packet load-sharing does very nicely balance load on links, reordering a flow's packets is often detrimental to its performance).
Joseph,
Thank you for your reply and advise.
I would supplement the customer with the advantages of per-destination configuration.
Kawakami, Tetsuo
