09-29-2010 12:46 PM - edited 03-06-2019 01:14 PM
Hello All.
Multicast video streaming is not working for only one VLAN (172.28.7.0/24)
How to find The router is detecting IGMP hosts to join group ?
Pls guide me to make this works.
Please find below few outputs from Router:
ip multicast-routing
interface GigabitEthernet1/0.3
ip address 172.28.7.254 255.255.255.0
ip pim sparse-dense-mode
ip igmp query-interval 125
end
sh ip igmp interface
GigabitEthernet1/0.3 is up, line protocol is up
Internet address is 172.28.7.254/24
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
IGMP query interval is 125 seconds
IGMP querier timeout is 250 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 113 joins, 109 leaves
Multicast routing is enabled on interface
Multicast TTL threshold is 0
Multicast designated router (DR) is 172.28.7.254 (this system)
IGMP querying router is 172.28.7.254 (this system)
No multicast groups joined by this system
sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter Group Accounted
230.0.0.2 GigabitEthernet1/0.3 00:22:50 00:06:13 172.28.7.114
09-29-2010 02:07 PM
If it is only for one vlan and multicast does not need to be routed you don't need ip pim sparse-dense-mode
Can you add
ip igmp snooping querier
and test again
Reza
09-29-2010 03:05 PM
From the IGMP group output, you have 172.28.7.114 as a host. Is that the host not receiving mcast stream? What switch is connecting to the router? Is it doing IGMP snooping?
Lei Tian
