Why always Logical slot/port = 14/1 is assigned to Etherchannel
mahesh18
Level 6
Level 6
Hi all,
On etherchannel i know when we create etherchannel  that link is logical link.
my question is why  always port channel  always start with   Logical slot/port   = 14/1
Is it standard convestion that Port channel  always start with slot 14?
many thanks
mahesh
kitanaka
Hi mahesh,
There is an internal logic to determine output port/ports in Catalyst6500 system
and some other products that is refered as Local Target Logic (LTL).
When you configure a port-channel and assign physical port/ports, a LTL will be allocated to
the port-channel and the physical port/ports will be programmed in the LTL.
Logical slot 14 is reservid for port-channels, 15 is reserved for primary supervisor and
16 is for secondary supervisor.
TAC or engineering team check them when doing some type of troubleshooting but
it is not important for most of users.
Kimihito.
kitanaka
Hi mahesh,
Kimihito.
Many thanks for reply.
is there any command which we can use to see these Logical slots?
mahesh
Many thanks for explanation
mahesh
