IP Multicsting L3 Switch
DevNet Engineer
Frequent Visitor
Frequent Visitor
Hello everyone,
I have a problem receiveing a multicast stream on a same vlan. My toplolgy - attached too - is as following:
SW1: configured with one vlan (vlan 80) and two hosts (host for multicast stream and the other for receiving, Rcvr -01.
SW2: configured as RP
SW3: configured with another vlan(vlan 90), which is attached for Receiver-2 (Rcvr-2)
Routing protocol:RIPv2
IP Multicasting: pim sparse-mode
all interfaces are pim sparse-mode enabled, including SVIs
I can receive the stream on Rcvr - 02 (vlan 90)
but i can not receive the stream on Rcvr - 01 (vlan 80), which is in the same vlan as the multicast source.
it is only working when i disable the igmp snooping for that vlan (vlan 80), but in this  case the multicast will be flooding, and then there is no use or Benefit from the pim sparse-mode
Any idea?
thanks
7 Replies 7
Joseph W. Doherty
"it is only working when i disable the igmp snooping for that vlan (vlan 80), but in this case the multicast will be flooding, and then there is no use or Benefit from the pim sparse-mode"
You're confusing flooding across networks (PIM-SM) vs. flooding ports with the same network (IGMP snooping).
Most likely reasons for your issue, either your receiver on the same VLAN isn't properly working with IGMP snooping or you've got something misconfigured. Insufficient information to comment further. (Posting the configs of your 3 switches might allow further help.)
Hello Joseph,
Here is the configurations of the switches:
SW1:
ip multicast-routing
interface Ethernet0/0
 switchport access vlan 80
 switchport mode access
 duplex auto
interface Ethernet0/1
 duplex auto
interface Ethernet0/2
 no switchport
 ip address 172.168.100.1 255.255.255.252
 ip pim sparse-mode
interface Vlan1
 no ip address
 shutdown
interface Vlan80
 ip address 192.168.80.1 255.255.255.0
 ip pim sparse-mode
router rip
 version 2
 network 0.0.0.0
 no auto-summary
ip pim rp-address 6.6.6.6
end
SW2:
interface Loopback6
 ip address 6.6.6.6 255.255.255.255
 ip pim sparse-mode
 no switchport
 ip address 172.168.100.2 255.255.255.252
 ip pim sparse-mode
interface Ethernet0/3
 no switchport
 ip address 172.168.200.2 255.255.255.252
 ip pim sparse-mode
interface Vlan1
 no ip address
 shutdown
router rip
 version 2
 network 0.0.0.0
 no auto-summary
end
SW3:
 switchport access vlan 90
 duplex auto
interface Vlan1
 no ip address
 shutdown
interface Vlan90
 ip address 192.168.90.1 255.255.255.0
 ip pim sparse-mode
router rip
 version 2
 network 0.0.0.0
 no auto-summary
end
and down below is the Output of the command - Show ip mroute - for each switch:
SW1:
(*, 224.0.1.40), 00:23:21/00:02:45, RP 6.6.6.6, flags: SJCL
  Incoming interface: Ethernet0/2, RPF nbr 172.168.100.2
  Outgoing interface list:
    Vlan80, Forward/Sparse, 00:23:19/00:02:45
SW2:
(*, 224.0.1.40), 00:18:21/00:02:43, RP 6.6.6.6, flags: SJCL
  Incoming interface: Null, RPF nbr 0.0.0.0
    Ethernet0/3, Forward/Sparse, 00:16:20/00:02:56
    Ethernet0/2, Forward/Sparse, 00:16:29/00:02:45
    Loopback6, Forward/Sparse, 00:18:19/00:02:43
SW3:
(*, 224.0.1.40), 00:20:32/00:02:28, RP 6.6.6.6, flags: SJCL
  Incoming interface: Ethernet0/3, RPF nbr 172.168.200.2
    Vlan90, Forward/Sparse, 00:20:30/00:02:28
Thanks a lot
I didn't notice any obvious errors in your configs.
What's the platform and IOS version for sw1?
I am using i86bi-linux-l2-adventerprisek9-15.2d.bin on GNS3 2.1.8.
i just got now real gears ( two Catalyst 3750-X), I will do the same confgiurations and see the results.
I will try to use the IP Services Licence.
Ah, perhaps GNS has an issue with L2 multicast. Let's us know how it goes with your 3750s.
Hi Joseph,
it works now, i can receive the multicast stream on all hosts. However, I don't understand the mroute table result, why the mutlicast source is joing the Group 239.255.255.250?
SW1:
(*, 239.255.255.250), 00:51:16/stopped, RP 2.2.2.2, flags: SJC
  Incoming interface: GigabitEthernet1/0/11, RPF nbr 172.168.100.1
    Vlan80, Forward/Sparse, 00:51:16/00:02:57
(192.168.90.20, 239.255.255.250), 00:04:25/00:01:09, flags: JT
    Vlan80, Forward/Sparse, 00:04:26/00:02:57
(*, 230.0.0.230), 00:51:14/stopped, RP 2.2.2.2, flags: SJCF
    Vlan80, Forward/Sparse, 00:51:14/00:02:57
(192.168.80.10, 230.0.0.230), 00:10:20/00:03:29, flags: FT
  Incoming interface: Vlan80, RPF nbr 0.0.0.0
    GigabitEthernet1/0/11, Forward/Sparse, 00:10:20/00:03:20, A
(*, 224.0.1.40), 00:51:26/00:02:15, RP 2.2.2.2, flags: SJPCL
  Outgoing interface list: Null
sw1#show ip igmp membership
 Channel/Group                  Reporter           Uptime        Exp.       Flags    Interface
 *,239.255.255.250         192.168.80.20   00:59:55     02:56      2A        Vl80
 *,230.0.0.230                 192.168.80.20   00:54:44     01:59      2A        Vl80
 *,224.0.1.40                   172.168.100.2   19:24:34     02:16      2LA      Gi1/0/11
First, it's good to read it works on the 3750 - confirms your configs (and my not seeing any issue with them).
Second, I would presume the 239.255.255.250 group is due to what the host is doing.
