IP NAT not working
Computerwiz24
I have a cable modem connected to a cisco 1841 router which i want to do NAT on. I cant get the NAT overload to work. In the show ip nat translations it appears my outside global and outside local IP addresses are incorrect. Has anybody seen this before?  My running config is attached.  Thank you
hello
your nat config looks okay so try changing your default route
no 0.0.0.0 0.0.0.0 xxx.xx.xxx (ISP Default Gateway)
ip route 0.0.0.0 0.0.0.0 dhcp
res
paul
Kind Regards
Paul
hello
res
paul
Kind Regards
Paul
Paul.
I changed the default route and also found an amateur mistake on my DNS address i set on the nic of the pc.  It is working great now.  Thank you for the help!
Adam
