ip nat outside source static and dynamic NAT aka PAT question
jasonww04
Below is the relevant part of my router config. What I'm trying to achieve is all traffic ultimately going to 68.164.204.26 be sent to 10.72.2.10 from all devices on the inside of my network. So, if host 10.61.23.101 wants to send to 68.164.204.26, it sends to 10.72.2.10 and the router NATs it. When the traffic arrives at 68.164.204.26, I want it to appear as if it came from 64.106.189.18, the WAN port on my router.
What am I missing?
interface FastEthernet1
ip address 64.106.189.18 255.255.255.248
ip accounting output-packets
ip nat outside
ip virtual-reassembly
load-interval 30
speed 100
full-duplex
crypto map VPN
interface FastEthernet2
switchport access vlan 2
interface Vlan2
ip address 10.72.1.2 255.255.0.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 64.106.189.17
ip nat inside source route-map NAT interface FastEthernet1 overload
ip nat inside source static udp 10.61.17.52 5060 64.106.189.18 5060 extendable
ip nat outside source static 68.164.204.26 10.72.2.10
ip access-list extended NAT
deny   ip 10.72.0.0 0.0.255.255 10.11.0.0 0.0.255.255
permit ip 10.72.0.0 0.0.255.255 any
route-map NAT permit 10
match ip address NAT
tsimons
I think you're thinking about this too hard.  How about this?
ip route 68.164.204.26 255.255.255.255 10.72.2.10
ip nat pool WAN 68.164.204.18 68.164.204.18 netmask 255.255.255.248
ip nat inside source list NAT pool WAN overload
set ip next-hop 64.106.189.17
Let me know if that works.
10.72.2.10 isn't actually on any device so I can't use it as a next hop. I want certain hosts to send traffic to 10.72.2.10 whenever they need to get to 68.164.204.26.
Julio Carvajal
Hello Jason,
On which interface is 10.61?
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
10.61 isn't on any interface. The 10.61. network is known to the router.
