Ip next-hop verify-availability problem
ran.rong_1
track 123 rtr 1 reachability
track 124 rtr 2 reachability
route-map PBR_IN permit 10
match ip address RB_SWI_IN RB_HK_IN
set ip next-hop verify-availability x.x.x.x 10 track 123
set ip next-hop verify-availability x.x.x.x 20 track 124
route-map PBR_OUT permit 10
match ip address RB_SWI_OUT RB_HK_OUT
control-plane
rtr 1
!--- Define and start Router 1.
type echo protocol ipIcmpEcho x.x.x.x
rtr schedule 1 life forever start-time now
rtr 2
!--- Define and start Router 2.
rtr schedule 2 life forever start-time now
interface GigabitEthernet0/0
ip policy route-map PBR_OUT
duplex auto
speed auto
interface GigabitEthernet0/1
ip policy route-map PBR_IN
duplex auto
speed auto
crypto map SDM_CMAP_1
service-policy input inbound
service-policy output outbound
This is my configuration and i wonder whether it need license or not!
The vendor didn't let me type it in my border-router,they say this configuration need license.
And they want us to buy it!
Is it necessary to buy the license?
Richard Burts
We do not have enough information to be able to correctly answer your question. If you tell us what platform, what version of code, what feature set (may be used or may be not used depending on version of code) and what licenses are applied then we would be in better position to answer your question. The output of show version would be a good place to start giving us the information.
Rick
Rick
IOF-3945E#show version
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.2(4)M4, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 14:38 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T5, RELEASE SOFTWARE (fc1)
IOF-3945E uptime is 17 hours, 25 minutes
System image file is "flash0:c3900e-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9 with 1792000K/305152
K bytes of memory.
Processor board ID FGL173811LR
8 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
1 cisco UCSE Module(s)
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE250/K9       FOC17356KNW
Technology Package License Information for Module:'c3900e'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
IOF-3945E#
Thank you for the information that I requested. According to this link
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9001265
Policy Based Routing is supported in the base license (which you have) but IP SLA requires the Data license (which you do not have). So probably the vendor is correct that to do verify-availability you may need the additional license.
Rick
Rick
