IP overlapping
maziyar daemi
Visitor
Dear : All,
How is possible to connect two same IP range offices through VPN(Site to Site VPN)?
- we do not want to re-IP
9 Replies 9
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
NAT.
Dear: Roberto and Joseph.
as i wrote before, am using VPN site to site.
Example:
Office 1: IP range: 10.1.1.0/24
Office 2 :IP range: 10.1.1.0/24
office 1  <--------Site to Site VPN IP sec  -----------> office 2
Hi I understood that and you need to use nat between the two sites, what security endpoint device are you using at each location ?
Just two routers.
Hi bro this should also work for your routers just look at the cli config section.
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/107992-IOSRouter-overlapping.html
Roberto,
Thanks a lot. thats useful info.
Roberto Kippins
Level 5
Level 5
This is possible you will need to use nat
Another option to consider might be L2TPv3.
Rick
Rick
Thank you Richard i  need to study more about it.
