IP overlapping
maziyar daemi
Visitor
Dear: All,
We have two offices : BO1 and BO2 with same range IP addresses.
Task: i would like to configure Site to Site VPN or (DMVPN)  through these offices.
Obstacle: We can not change Private IP addresses of these offices, therefore we will have IP overlapping.
Solution?
Great Thanks.
I apologize but I have no knowledge of Enterprise devices features.
Maybe you can post the question on this forum to get a better answer:
LAN, Switching and Routing
I hope this helps
7 Replies 7
cchamorr
Level 11
Level 11
The only product from the small business that will allow you to do this is the ISA500 series routers, but unfortunately they have been discontinued. You may want to check with enterprise devices as I'm very positive they will be able to do what you are trying to accomplish here.
I hope this was helpful
Hello cchamorr,
Thank you very Much.
I just noticed you replied to this question.
Please don't forget to rate the answer or mark it as correct if it was useful to you so that other users can benefit from it.
Thank you for posting
Would you please let me know, which types of enterprise models as you prefer for this issue?
I hope this helps
Great Thanks.
