ip overlapping
123.45.0./16 i have to divide it in two rooms something like this
room 1 will have 256 IP addresses and room 2 will have 512 IP addresses
what i have done is this
F1/0 :  123.45.0.1 255.255.255.0
FA1 (Which is the Pc in Room 1)  : 123.45.0.3 255.255.255.0
F2/0: 123.45.1.2 255.255.254.0
FAS1 (Which is the Pc in Room 2) 123.45.1.4 255.255.254.0
now when i try to no shut down  on interface F2/0
i get an error saying IP overlaps with F1/0
which is the link from F1/0 to FAS1(in room 2)
please note i am able to ping successfully from FA1 to F1/0
can some one please tell me what m doing wrong
luis_cordova
Hi @nuclearpopsicle201,
The problem is in the network indicated in F2/0.
This, if it has a mask /23 and the bit 1 in the third octet, it's actually a network 123.45.0.0/23, which includes the F1/0 network.
ip F2/0= 123.45.0000 000|1.0000 0000/23.
I recommend you always start the network division with the network with the most IP requirement.
In your case:
512 IP = 123.45.0.0/23
256 IP = 123.45.2.0/24
