IP Plus Feature Set for a Cisco 3560E-48PD
networkguy1038
I found that to utilize the TTCP test tool (which tests the throughput between 2 devices), it requires the IOS feature set IP Plus. Can anyone help me to find this IOS version for the Cisco 3560E-48PD? Thanks in advance.
Edison Ortiz
The universal code provides all features not found in IP Base code. To open the extra features, you need to contact your Cisco reseller and purchase a key. With the key, you can upgrade to IP Plus, IP Services, Advanced IP Services, etc.
HTH,
__
Edison.
