IP range
Fadi.1984
Community Member
Hiii Team,
Maybe it's a simple question, can i use network 172.15.1.0 on class B  to assign private addresses?? for examle: 172.15.1.1- 40
thank you
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Could you?  Yes.
Should you?  No.
172.15.x.x is public address space.  If you were to use it, you need to insure you wouldn't leak it to the Internet (likely won't).  But, you'll likely make it impossible to reach those public IP addresses, assuming you have or want Internet access.
The private Class B address space is:
172.16.0.0 - 172.31.255.255 (172.16/12 prefix)
Peter Paluch
Hello Fadi,
The range 172.15.x.x does not belong to any private IP range. It is conceivable that the IP addresses within this range are used publicly. Therefore, you should not use these addresses until you have been legally assigned them by your provider or by an address authority.
Best regards,
Peter
